I switched off my phone last night. Then I switch on it. When I press and hold the power button, it vibrates but nothing displays and no respone (black screen). My battery was 95%. Then, today when I tried to switch it on, a red light flashes 3 times. I tried many times but the same problem. I charged it for 3 hours but same problem and I also tried Volume Up + Power Button but it also fails. Please help me.... Please...
¡Resuelto! Ir a solución.
Maybe you should to contact your local Sony Xperia Care, it seems that it´s the best solution for you at this moment.
No, Even Sony PC Companion is not detecting my phone. Please help..... please help.....
Is there any other way? Please tell me....
Hi garvmaggu
if you have desktop computer, then remove battery and replace it back , connect the phone to back of your computer USB, press and hold the volume up button for few seconds then press power button, you can feel vibration on phone, release the buttons, and see you able to see anything on screen.
Manjuboyz
NOTE:
Rate me(Kudos) If you are happy with my Resolution, Thanks
Replace it back means what?
Download sony update service and repair:
http://www.sonymobile.com/gb/tools/update-service/
If you want to force shut down,check this out:
Replace it back means put it back where you took it from (plug it back into the phone).
Update Service also failed... ....Another Way? Please..
Tried... but failed.
