Speaker not working after put in water in Z
SOLVED
Ishak
Visitor
The speaker of my phone does not working properly after put in water.
sound can not come out due to water inside the speaker area..
it does not drain?
anybody faced this problem?
what to do?
1 ACCEPTED SOLUTION
Accepted Solutions
JakeSully
Contributor
let your phone dry for a whille once it's fully dry your speakers will sound normal again Slightly_smiling_Face
It's normal that speakers wont work fully after having the phone in water.
11 REPLIES 11
JakeSully
Contributor
Ishak
Visitor
Actually, Does the speaker getting wet will make it damage?
Zann_H
Enthusiast
i don't think the actual speaker get wet. it's the speaker vent(those tiny holes) that is blocked with water. and since the phone is certified water resistant, the speaker is not supposed to get damaged with contact from water.
Ishak
Visitor
Will we get warranty if any damage with water?
Zann_H
Enthusiast
yes. as long as all flaps are closed and the indicator in those flaps doesn't turn red(to indicate that water has went in)
Ishak
Visitor
Thanks for this information 🙂
NicEGi
Visitor
You should bring the water out of the speaker with your mouth.
then dry it with cold hair dryer.then wait,it will be perfect again.
mine is perfect now.then blow a little in it...it's normal.don't worry.:smileyhappy:
and it's fine and doesn't hurt your phone.
coops_69
Visitor
Lol I did the same being a smart ass to my mates with samsungs and I phones.. They all laughed but it dryed out in like 10 mins. Just blow the holes out aha
rnraj866
Visitor
When water falls falls on my phone.... Water goes in speaker and loudness of speaker goes down
This has happened 2-3 times
Is this a problem????
