well im suffering from ads while using chrome may be everysite i want to open change into another site(ad) ... tested chrome on computer but this does not happen any idea?i cant use my phone browsing any more
Solved! Go to Solution.
I have tried closing all tabs. I still get the error whenever I open a webpage off my facebook wall.
You are sure that all tabs are closed and you just didn't swipe Chrome from recent apps? If your phone is updated to Android 5.0 apps and tabs will be merged by default. You can turn that off from Chrome -> [menu -> Settings. To the right of the address bar you should then see a box with a number telling you how many tabs you have open.
As clearing data for Chrome helped for a while it makes me believe this is the cause.
But if it's not, i recommend that you try if the same thing happens on another internet connection.
check it ...it describes my problem with ads...90% of sites give same ad...10% no ads <.< i hated that
If this happens also in safe mode, i would suspect the internet connection. You're not using any free ad supported internet connection or something like that? It could for example be that when the phone makes a DNS-request, the DNS returns another page (an ad).
I think it's time to repair the phone with PCC > once you are done with that > do NOT enter your Gmail account > test chrome and report back.
I'm leaving that to be the last hope… for now I noticed my computer has same ad any idea ?
Check this out
and this
It's time to use PCC and do NOT use the same Gmail just to test the phone.
this gave me an answer for rooted devices mine unrooted there must be another solution i can't lose my data for now <.<
One does give you an solution w/ root access but you must repair your phone with PCC, again, it seems to be malware on your phone and a virus on your computer
