Sony Xperia Z1 Video recording problem!
SOLVED
Cher29
Visitor
Whenever I try to take a video with my mobile phone, the video starts to record normally but gets stuck a little bit than continues recording. When you play the video, it shows the same (first all good than in a couple of seconds gets stuck than continues, and that goes on repeatedly).. The internal storage is not full, so I doubt it's that.
The video is recorded like there's some "lag" I guess. This happenes everytime. Anyone knows how to fix this?
Sorry if it's a repeated question, but I didn't know how to explain it let alone find an answer :c
1 ACCEPTED SOLUTION
Accepted Solutions
Jake-SonyXperia
Champion
Here are Bridge for Mac instructions.
Bridge for Mac:
1. Launch Bridge for MAC without the handset connected.
2. On the Main Window select "Xperia > Repair Xperia Device".
3. Ensure the phone is charged and select "Ok" in the following window.
4. Select Continue on the following page.
5. Wait until the initialising step is finished the continue as below.
6 . Select your model of phone from the list that appears
7. Follow the connection steps that appear, ensuring that you are holding the relevant button down before during and after the connection phase until the update/repair begins.
13 REPLIES 13
profile.country.RO.title
_alexdon_
What if you try to record to internal? I suspect a low class or fake memory card.
alexdon
Cher29
Visitor
I am recording on the internal storage. Sorry my bad for refering it as memory card.
_alexdon_
Try settings-apps-all-camera,force stop and clear data. Check how it is.
alexdon
Cher29
Visitor
Tried it but after about 30s the video was not continuous anymore..
Jake-SonyXperia
Champion
Hi Cher29,
Welcome to the community,
Are you getting the same result in Safemode?
Safemode instructions
Cher29
Visitor
Hi, I tried it in safe mode and it happened after about 13s and again 3s after.
_alexdon_
You may need to perform a software repair using PC Companion.The process will erase all internal memory.You might need to charge your device for about 1-2 hours before so the device has at least 80% battery.
Make sure the device is not connected to computer or laptop and turned off (sometimes you have to press power button and volume up until the device vibrates 3 times or on some devices you have to press the small button near the SIM tray or on the back of the device).
Open PC companion->support zone->phone/tablet software update->repair my phone/tablet blue highlighted.Follow the steps given,do not connect your phone until prompted to press volume down while plugging USB cable. If PC companion does not start the repair process, you might need to run it in compatibility mode with Windows 7 (in some cases XP).
alexdon
Cher29
Visitor
And it's not possible to do this on a macbook right?
I will try this out and let you know if it worked. Thanks.
_alexdon_
