How to solve Battery checker problem in VAIO E-series notebook?
SOLVED
profile.country.en_IN.title
Arulsubramaniam
Visitor
Hello Guys,
I have a problem after re-installing the OS. The battery checker is telling that , "Your battery is not connected properly, Please click OK to hibernate". But battery is properly connected and sufficient charge is available.
What might be the problem?
Message was edited by: Arulsubramaniam
Tags (2)
1 ACCEPTED SOLUTION
Accepted Solutions
Arulsubramaniam
Visitor
Yeah. I have re-installed the OS .
As I have re-installed my OS, I have to install all VAIO softwares including VAIO power management, Battery checker. So I did.
Thanks for giving a hint.
ISBmgr.exe was running and the problem was due to that only. I closed that process. Now the Laptop is OK.
I'm using the same original battery.
But I'm curious to know, what is the problem in re-installation? Don't I have rights to do it?
In my point of view, Re-installation should not affect software behaviour. Am I right?
4 REPLIES 4
Blencogo
Have you reinstalled the original Sony operating system or have you installed a retail version?
Have you reinstalled Vaio Power Management?
Have you reinstalled the Battery Checker utility?
Do you have a process 'ISBMgr.exe' running at starup? Check in Task Manager.
Are you using the original battery?
:thinking:
Arulsubramaniam
Visitor
Blencogo
I don't know what has happened - a full system recovery should reinstall all the software properly.
I just know that ISBMgr causes the message.
You could try asking Vaio Support but I guess it is a one off - at least you will know what  to do next time!!!
:thinking:
Arulsubramaniam
Visitor
Yeah.. It is good to know that, even well known brand has some unknown exceptions..
It will be better, if they fix it :slight_smile:
Anyway, thanx for replying.. Meet you soon in next post .
