How to connect my vgn-fs315e to hd ready tv using vga cable and jack plugs
profile.country.en_GB.title
hollalegs
Visitor
How do i connect my vaio VGN-FS315E to hd ready tv using vga port and jack plugs
1 REPLY 1
Blencogo
That will depend on the connections on the TV.
If the TV has a PC D-SUB 15-pin port then this will connect direct to the Vaio's VGA port.
If the TV has no PC port then you will need a converter box to convert the VGA signal (RGB) to composite Video or S-Video.
In both cases you will need to connect the sound separately - from the headphone output on the Vaio to the analogue phono inputs on the TV.
You will need a converter box like one of these: -
http://www.amazon.co.uk/s/?ie=UTF8&keywords=vga+to+tv+converter+box&tag=googhydr-21&index=aps&hvadid...
The converter cables without the box will not work.  I see there is a VGA to HDMI box available also.
:wink:
