Hi,
I'm trying to connect my panasonic dv camera (NV-GS3) to an RS 704 using dv gate but the programme will not see the camera. Has anyone else had similar problems connecting dv cameras ?
Are you using an iLink cable?
yes
i have looked there but there is nothing relevent
Ah. I had the same problem but there was a download at Vaio-Link which sorted it out. Does it work in Click to DVD?
it dosnt work with click to dvd either! what was it that you had to download ?
thanks
I downloaded this one:
Click to DVD Upgrade Program 1.4.04.07210
Important Notes!
The requirements for installing Click to DVD Upgrade Program 1.4.04.07210 are:
1.DirectX 9 or later
2.Windows Media Player 9
3.Click to DVD 1.4.01 or 1.04.02:
-If you have Click to DVD 1.3, you must first download and install Click to DVD 1.4.01
-If you have Click to DVD 1.2 or earlier, you must first download and install Click to DVD 1.3, and then download and install Click to DVD 1.4.01.
New feature
This version supports Windows XP SP2
Fixed bugs
-Click to DVD fails to detect a camcorder after Windows XP SP2 is installed.
-Unable to import movies over 8 hours (max 12 hours)
-Hard disk space insufficient error occurs when you try to burn DVD from MPEG1 movie even if there's enough disk space.
-Click to DVD can not capture automatically from specific camcorders (DCR-HC30/40)
-Click to DVD Automatic Mode fails to burn DVD if free disk space is 6GB - 10GB
Applicable Models
PCGA-DDRW1
PCGA-DVRW1
PCG-FR215S
PCG-FR215H
PCG-FR315S
PCG-FR415S
PCG-K115Z
PCG-K115S
PCG-GRT796SP
PCG-GRT715M
PCG-GRT715E
PCG-GRT785E
PCG-GRT716S
PCG-GRT786M
PCG-GRT815E
PCG-GRT815M
PCG-GRT816S
PCG-GRT896HP
PCG-GRT896SP
PCG-GRX616SP
PCG-GRT996ZP
PCG-GRT996VP
PCG-GRT916Z
PCG-GRT916V
PCG-GRT915M
PCG-GRV616S
PCG-Z1XSP
PCG-GRX516SP
PCG-GRZ615M
PCV-RX404
PCV-RX405
PCV-RX406
PCV-RX407
PCV-RX417
PCV-RXG408
PCV-RX502
PCV-RX503
PCV-RX504
PCV-RX512
PCV-RX514
PCV-RX515
PCV-RX612
PCV-RX624
PCV-RX644
PCV-RS102
PCV-RS104
PCV-RS114
PCV-RS122
PCV-RS123
PCV-RS142
PCV-RS144
PCV-RS204
PCV-RS206
PCV-RS212
PCV-RS216
PCV-RS222
PCV-RS224
PCV-RS226
PCV-RS246
PCV-RS302
PCV-RS304
PCV-RS306
PCV-RS312E
PCV-RS314E
PCV-RS316
PCV-RS322E
PCV-RS324E
PCV-RS326
PCV-RS344
PCV-RS346
PCV-RS406
PCV-RS404
PCV-RS402
PCV-RSM21
PCV-RSM22
PCV-RSM31
PCV-RXM21
PCV-RXM22
PCV-RZ102
PCV-RZ103
PCV-RZ104
PCV-RZ201
PCV-RZ211
PCV-RZ221
PCV-RZ301
PCV-RZ302
PCV-RZ304
PCV-RZ311
PCV-RZ312
PCV-RZ314
PCV-RZ321
PCV-RZ322
PCV-RZ324
PCV-RZ402P
PCV-RZ404
PCV-RZ414
PCV-RZ422P
PCV-RZ424
PCV-RZ504
PCV-RZ502P
PCV-RS504
PCV-RS502
PCV-W1/G
PCV-W1/D
PCV-W1/F
PCV-V1/G
PCV-V1/D
PCV-V1/F
PCV-V1/I
PCV-W2
VGN-A197XP
VGN-A197VP
VGN-A195HP
VGN-A117S
VGN-A115S
PCG-TR5MP
PCV-RS604
PCV-RS602
VGN-X505VP
VGN-S1XP
VGN-S1VP
PCG-K215B
PCG-K215Z
PCG-K215S
PCG-K215M
Download and Installation Instructions
1.Download the file CTD_140407210.zip and save it to a download directory.
2.Right-click CTD_140407210.zip and select Extract All...
3.Follow the on-screen instructions to extract CTD_140407210.zip to a folder (note this folder for reference)
4.Open the folder in which you have extracted the compressed file
5.Double-lick SETUP
6.Click Next.
7.Wait while SETUP installs the new program.
8.Click Finish
From the Panasonic help centre:
Q. My PC running Windows XP cannot communicate via Firewire with my Panasonic DV camcorder.
A. Some Windows XP installations are unable to use some DV camcorders as a video source and cannot therefore detect the camcorder in the video editing software. This problem can some times be rectified by downloading an update from Microsoft's website at http://support.microsoft.com by searching for their knowledge base entry 329256.
If your Windows XP installation has been updated to Service Pack 1 however, then there is also an update available from the same website which is covered by Microsoft's knowledge base entry 810032.
My machine has come with service pack 2 and the patch wont load as it it ser 2!
ANY IDEAS
thanks
