Battery Iife differences between PCGA-BP2NY and BP2NX in GRT786M ?
ravijain
Visitor
Are there any differences? Is there any way to improve the miserably short life of the BP2NX ? (~60MINS)
2 REPLIES 2
scr38
Visitor
Both are rated at 14.8 volts-4000MaH. The BP2NY is for use with processors over 3.06 GHz. There appears to be a slight difference in the cases at the connector end. I suspect there are internal electrical differences between the two, such as current limiting. The BP2NY is set up for higher current draw for the faster processors. I don't think there would be any difference in life between the two; but you must use the BP2NY with the faster processors.
ravijain
Visitor
So...has anyone managed to watch a full dvd movie on a single battey charge with a GRT786M?
