Whenever I try to take a video with my mobile phone, the video starts to record normally but gets stuck a little bit than continues recording. When you play the video, it shows the same (first all good than in a couple of seconds gets stuck than continues, and that goes on repeatedly).. The internal storage is not full, so I doubt it's that.
The video is recorded like there's some "lag" I guess. This happenes everytime. Anyone knows how to fix this?
Sorry if it's a repeated question, but I didn't know how to explain it let alone find an answer :c
Solved! Go to Solution.
Here are Bridge for Mac instructions.
Bridge for Mac:
1. Launch Bridge for MAC without the handset connected.
2. On the Main Window select "Xperia > Repair Xperia Device".
3. Ensure the phone is charged and select "Ok" in the following window.
4. Select Continue on the following page.
5. Wait until the initialising step is finished the continue as below.
6 . Select your model of phone from the list that appears
7. Follow the connection steps that appear, ensuring that you are holding the relevant button down before during and after the connection phase until the update/repair begins.
I tried this and after a while this message popped up
Tried it for the second time and it worked.. I will let you know if it fixed the camera issue.
Great hope it all worked out for you
