How do I switch my Z3+ to PTP mode instead of MTP when connected to PC?
Yes, I want my Z3+ connected with PTP mode.
Solved! Go to Solution.
Not sure if this helps but check it out:
Unfortunately the Xperia Z3+ doesn't have PTP mode, it only supports MTP.
I've just discovered this today myself whilst installing Helium/Carbon.
PTP is needed for that to work and is activated under USB debugging under developer options under settings.
