contact ringtone problem xperia z3
SOLVED
cornelt
Visitor
Hi, after last update,my xperia z3 doesn't ring the ringtone assigned to a specific contact but the default ringtone please help.
1 ACCEPTED SOLUTION
Accepted Solutions
Uliwooly
@cornelt are the notification sounds/music stored on the internal storage?
8 REPLIES 8
Uliwooly
Notification ringtone while receiving calls or messages?
cornelt
Visitor
I didn't check for messages yet, observed for receiving calls
Uliwooly
cornelt
Visitor
no, on the microsd card.tryed also copying to internal memory. and BTW got the same problem with the messages
cornelt
Visitor
ok, found the solution: moved the ringtones to internal mem. and re-edit the contact. it worked. too bad for all this work...
Uliwooly
I'm glad to hear that it's working fine now.
cornelt
Visitor
thank you for gaving me the idea
ganiutzu_
Visitor
hi,same problem for 2 xperia z3,i copy my music to ring tones folder in internal memory and then was ok,not a good uppgrade lolly pop.
