Firmware Update 1.20 for Pioneer DVR-107DVA
luigiravanetti
Visitor
I need information about firmware in object. I am not sure what this patch does. Upgrade the dvd rw drive for the write on the dual layer dvd+r? Can this firmware cause problems to the sistem?:smileyconfused: :thinking: :thinking: :thinking:
6 REPLIES 6
jammold
Explorer
Your firmware upgrade should not cause any harm to your computer. Firmware is provided to fix errors such as media recognition errors (DVD+R in your case), and in some cases used to repair errors in the microcode.
Generally, the the of thumb I use is if it is highly benificial, then I download and install it. Sony will briefly explain what the upgrade will do, and offer a disclaimer.
I would use caution on upgrading the BIOS unless you need to for Service Pack 2 compliance, or to fix serious underlying issues (such as corrupt ACPI/PCI-IRQ Routing errors).
Mandy
Visitor
I would go a little further and say any firmware upgrade should be treated with the same caution, Bios or otherwise both could render hardware useless. I concede a buggered drive is not as costly as a useless computer but the risks are the same.
Despite this I have used both several times without problems .
TygerTyger
Visitor
Yep I'm with James on this. Unless there's a big benefit or I'm already having problems I ignore firmware updates and BIOS upgrades.
Mandy
Visitor
Tyger,
Unless I got out of the wrong side of bed today it is "me " exercising caution with both and James only exercising caution with BIOS updates.:smileysad:
profile.country.en_GB.title
kee-lo_
Member
LOL Mandy,
As the others have said if it aint broke, then leave it be.
TygerTyger
Visitor
Ohhhhhhhhhhhhh yeah. Doi me, I'm with Mandy. And James.
