Hi,pls can someone help me,i just Install Window 7 on my FZ11Z laptop but now i tried to Recover my laptop back to Original, after Pressing F10 Key nothing happen,the screen was just blank i don´t have the Recovery on a disk.Can someone help me pls
It sounds like Windows 7 has formatted your drive and the Recovery Partition has been erased. If you did not make Recovery DVDs then you will have to purchase a set of recovery discs from Sony.
Can you get into the BIOS by tapping F2 during the boot sequence? If so try resetting the BIOS to default values and then try tapping F10 again. It won't help if the partition has been formatted but it may help if the partition is still there.
