I've just bought a str-da3600es AV Amp and it has 4 LAN sockets in the back.
The book request that you only use1 .
Could someone tell me what the other 3 are for ?.
It's does seem strange to fit these sockets and not tell you how to use all 4
thank you
Solved! Go to Solution.
Its just a hub - actually quite useful, so you could run one long cable into the amp and then shorter cables direct from your amp to PS3/TV etc to connect them to t'nterweb.
Thanks
Thank you
You would think they would make more of it in the manual.
I've got it pluged intoa hub at presentbut my hub has an input socket and 4 output.
Do you know which port is the input.
I'm sorry if this sounds silly but i'm to ofay with networks .
Looking at how its setup probably it won't matter. Either way it won't damage anything by trial and error
Thanks
Thats great thank you
and thank you for replying so promtley
alan
