Hello!
I have a problem where when I turn my TV on, the sound system only works about half of the time (even when it says TV on the unit). If it doesn't work, I can switch input (on the TV), and that will sometimes fix it. Otherwise, I have to go into the home menu and manually switch back to TV.
My girlfriend is getting ***** off at this.
Is there a way to not have my Samsung TV remote turn on the sound system or set it so the tv always just uses the tv speakers? I would rather have to manually engage the speakers when I want to watch TV with surround than have the girlfriend get mad at me.
Thanks!
Solved! Go to Solution.
Hi there
Disable 'Control for HDMI' in the HDMI Settings, in the System Settings menu. This will prevent the TV from turning on the BDV-N7200W
Cheers
