MDR-RF811RK Wireless Headphones - new.
They work fine but when charging the red light never goes out ( 40 hours or more on charge). Manual says that the light goes out when charging is complete. That means I can never tell whether the headphones are fully charged and can be expected to last the required amount of time.
Is there a solution ?
Solved! Go to Solution.
Hi,
Please take the headphones from the charger and use them until the batteries are empty. Put them then back on the charger. The charging light then should turn off after ~16h.
Cheers
Peter
If the issue remains after what Peter suggested, take the headphones back to the point of sale for an exchange under warranty.
That's good to hear! Don't forget to mark Peter's comment as an accepted solution.
