Lost sound
RESUELTAS
Keefyt18
Lost sound
After update sound lost on apps tried reset no luck help
1 SOLUCIÓN ACEPTADA
Soluciones aceptadas
Joe_Dohn
Especialista
What TV are we talking about here and what update version are you referring to? Also what apps have this issue?
6 RESPUESTAS 6
Joe_Dohn
Especialista
Keefyt18
The tv is a Bravia kd43xh8196 software version
keenel4.9.125 apps that had problems prime Disney you tube these only apps I have on
have managed to fix it using my phone as a hot spot and a factory reset (after unplugging everything and turning it off for 5 mins
i can only assume some problem with router ???
since reconnected router and still works
keith Tretton
Joe_Dohn
Especialista
This seems more like a software glitch since it's working now.
Keefyt18
I presume it is but don’t comprehend why doing a factory reset using my phone as a hotspot as opposed to doing a factory reset using internet connection directly??????
Joe_Dohn
Especialista
The factory reset doesn't use Internet, I think the reset itself solved it, which is great!
profile.country.US.title
Semez1
I had similar problem disconnect the power wait 20 sec
That fixed the problem
