Xperia z3 Compact top and bottom Touch screen not responding
Johnalds81
Visitante
Hi Sony,
I've got this touch screen iresponsive on the top and bottom. I was not able to pulldown the notification and shortcuts menu when in portrait mode. Now even the bottom part of the screen starting become iresponsive. Pressing the back/menu/taskmenu starting to mulfunction.
Please help me fix this issue.
156 RESPUESTAS 156
Phy
Leyenda
Leyenda
test the screen.
1. settings
2. about phone
3. diagnostics
4. test
5. test the screen
Phy
Leyenda
Leyenda
Or you can repair the phone with PC Companion.
http://support.sonymobile.com/gb/tools/pc-companion/
MaximeL
Visitante
I have exactly the same problem, repairing the phone with PC Companion didn't fix it.
The phone is only 1 year and half old, I am kind of disappointed by Sony!
AyysforOuus
Visitante
Made an account just to say "same!!" Also, I'm not quite sure how failing the touch screen test does anything.
Emir1
Héroe
Hi!
If you have already tried a software repair using Xperia Companion and it did not help, then I would recommend getting in touch with your Local support in order to have your device sent to an authorized service center.
@AyysforOuus the main reason for trying the test in Diagnostics is to see if the display responds to that area, or if it may be software related. If you are able to clear the area where the buttons don't respond, you could try a software repair to see if that helps.
zik
Visitante
I have exactly the same problem (top and bottom not responsive). I tried the software repair and it did not fix the problem. I also tried the screen diagnosis test and it passed. The problem with the diagnosis test it that it only tests the main area of the screen, it does not test the notification area and the bottom navigations (shortcut) keys.
Emir1
Héroe
I am sorry to hear that @zik. Slightly_frowning_Face
In this case I recommend that you contact your Local support so that they can assist you in sending in your device to an authorized service center to have it checked by a technician.
camilleri
Visitante
Same here only that for me is the top and left borders of the touchscreen. Phone is only 1 and a half years old and out of warranty. Any ideas how much would the repair center charge for this?
Emir1
Héroe
Hi @camilleri, sorry about your phone. Slightly_frowning_Face
I am afraid that it's not possible for me to determine what the cost of the repair may be in your specific case, since the local service routines, costs, consumer laws and warranty terms vary on a market-to-market basis. My suggestion would be to get in touch with your Local support to see if they may have some information regarding the local rates, but there is also the possibility that you have to first have your device examined before a quotation may be issued. In any case, it would be best to hear your local support team out first! Slightly_smiling_Face
