Solved! Go to Solution.
if the phone start to vibrate again. then you need to use the soft off switch . it is a red color switch. it is located in the flap that contain sim. just press the button and it will make the phone to switch off under abnormal condition
I did
bought my xperia z2 two days ago. took it in the pool and now it wornt turn on. **bleep**
I used my phone under water for minuites and took 2 pictures, the flaps were 100% secure, the depth was less than 50 cm, and time in totall less than 5 min, now the monitor doesn't work, just the monitor, I am recieving calls by sliding on a dark screen, I can use the touch screen to unlock a pattern I can't see, I hear the sounds, just a dark monitor, now what do I do?
After not more than two min. At the pool my z2 2 cameras be cloudy and water inside camera that is some kind of cheating
