Solved! Go to Solution.
Exactly the same in my case
This device is not water proof
It's just a BIG LIE
It's only a question of Luck when you buy it... I was not lucky, so I've lost 520 eur !!
I've had mine dead the first day !! Only a simple picture under water, and the device is dead.
SONY simply says: NOT COVERED because it's wet
What does this mean ? It's water proof of not ?
Definitelly it's NOT, because it's not warantied if you get it wet.
I will NEVER EVER buy anything to SONY again !!!
SONY is conning people !!
If you as a owner is unsure of your phone being water tight feel free to test it at any sony store that sells the phone. If there is an issue they will repace it if not at least you tried and now know how to seal the phone correctly.
First time used in a pool and water inside, now touch screen is not working
@DocBehr wrote:First time used in a pool and water inside, now touch screen is not working
You're not supposed to use the device in a pool. The chlorine will mess with the phone.
Brand new sony z2, and waterdamage after taking pictures in the pool, outrageous that Sony does not replace phones, because i am not the first and neither the last person... after this a Sony z3?? i dont think so.... Sony we consumers are your backbone, if you wont take care of us, you will fall. I dont understand the foolish policy you Sony have. This is not right, i have to buy a new?? PLEASE !!
Consumer from Sweden
I really don't understand people that actually take photos under water. This is not a professional device for taking pictures under water. I understand waterproof more to use it with wet hands, if somehow a rain catch you, etc.
Have you read this in operating manuals: "...Even if your device is resistant to dust and water, you should avoid exposing it unnecessarily to environments with excessive dust, sand and mud or to moist environments with extreme high or low temperatures. The waterproof ability of the micro USB port, the SIM card slot, the memory card slot and the headset jack cannot be guaranteed in all environments or conditions ...".
@srv1 wrote:I really don't understand people that actually take photos under water. This is not a professional device for taking pictures under water. I understand waterproof more to use it with wet hands, if somehow a rain catch you, etc.
Sorry, have to disagree......i have seen quite a few pictures/ videos from people either on holiday swimming underwater taking videos which were cracking videos or people just trying it out elsewhere.....things you are NOT meant to do is use it where there is water pressure ie jacuzzis or showers or where there is the risk of chlorine getting on the phone.....
Common sense should tell you to steer clear of of these situations also sand/mud high water temp surely.......also taking it too deep underwater......:smileyrolleyes:
