Walkman Issues
SOLVED
Puppet
Visitor
Walkman Issues
I've used Media Go to transfer all my mp3's to my sd card.  Now the phone says "cannot play song" on most of my library.  I've actually collected almost all of my library over the past 10 years from borrowing or buying cd's, so I'm not exactly thrilled at the thought of purchasing music again just because I purchased this phone, as my old phone played my music fine.  Any suggestions?
1 ACCEPTED SOLUTION
Accepted Solutions
Uliwooly
I think the SD card its faulty, you should reformat the SD card
10 REPLIES 10
Uliwooly
Try this
settings > apps > all > walkman > clear everything > stop walkman > restart your phone > check again
Puppet
Visitor
Thank you, so far seems to be working on the first 6 songs I transferred.  Hopefully it fixes it for good
Uliwooly
Anytime
don't forget to give Kudos
azzido
Enthusiast
I experience other issues with newest Walkman on my Z:
From time to time when I am listening to the music it stops playing for a second for example when I turn off / on the screen = it will lag for a moment which means it stops playing the music for about 1 sec or sometimes 0,5s. and continue to play it after that Slightly_frowning_Face
It happens from time to time also when I am starting other apps Slightly_frowning_Face
I am on newest android 4.2.2.
I believe it can be fixed and play the music fluent no matter what I am oing, turning on/off the screen or starting other apps.
Puppet
Visitor
Okay, now it tries to play the songs, but skips? Wth? lmfao, my digital cd is skipping....
Puppet
Visitor
And restarted my phone but the music is no longer there.  Could it be a faulty sd card?  If so is there a way to test it?
Uliwooly
Puppet
Visitor
I did that first thing when I put it into the phone.  I didn't want to risk incompatibility issues from the old phone.  Do you happen to know a way I could stress test the sd card or something similar to tell if it is the card for sure before I go spend the money on another one?
Puppet
Visitor
Found another sd card and it solved the problem I THINK.  Thank you again for your patience
