Hello,
I have a problem with my style cover. I have signal, but the icon signal doesn't display corectly. Can someone help me?
Thanks
P.S. in save mode i have the same issue
Solved! Go to Solution.
I've received information that support for this will be added in the update to Android 6.0.
Update:
The firmware version that adds support for this is 32.1.A.1.185.
Does this happen when you are not using the style cover as well?
No, It happens only when i use style cover. Any suggest?
Nobody?:(
I'm not sure it might be related but do you have stamina mode on or any battery apps or antivirus?
I tryed with dark and blue. Same issue on both:(
I will forward this internally for further investigation.
Thanks
