Sony Xperia Z2, Headphone volume too low
SOLVED
RainbowPuke
Visitor
Hi, I listen to music on Spotify, and was very satisfied with the sound quality and volume, up until recently. All of a sudden the volume became low not only on Spotify, all sounds. Even the maximum volume is hard to hear. There is nothing wrong with the earphones because I tried them on different devices and it works perfectly. I think it is a software issue, please help!
Thanks.
1 ACCEPTED SOLUTION
Accepted Solutions
Uliwooly
@RainbowPuke
install PCC > run PCC > click on support zone > follow the steps > reinstall the latest update
PC Companion (PCC)
Bridge (for Mac)
Alternatives on How to backup Xperias
http://talk.sonymobile.com/thread/36355
6 REPLIES 6
Uliwooly
@RainbowPuke
Walkman/music > settings > audio settings > sound effects > headphone settings
Jake-SonyXperia
Champion
Hi RainbowPuke,
Welcome to the community.
You could also try booting in to safemode to see if the issue continues, if it does not then it is third party if it does then it could be OS based and a software repair or following Uliwoolys instructions would be the way to go.
Safemode instructions
RainbowPuke
Visitor
Hi Jake,
I tried booting in safemode, there is no difference. And I already tried other settings, but I used the same settings before I had the issue, so I don't think that's the problem. How do I repair the OS?
Uliwooly
@RainbowPuke
PC Companion (PCC)
Bridge (for Mac)
Jake-SonyXperia
Champion
Let us know how you get on with the software repair. If you still have issues you can always call Sony Mobile within your region.
Use my signature below for contact details if needed.
sgizmo
Visitor
What wrong with this device? I connect a sound system which cost 400e but volume is to low. And if I connect cheap china player all is good. It is not good.
