Hi.
So i recently installed the latest 2015 software update onto my Sony Xperia Z and at one stage, it asked for me to unplug the phone, open the case and remove the battery and put it back on. I tried my best to open it but since it is a waterproof model, it is really hard to open the back of the phone. MY PHONE SOMEHOW GOT MESSED UP AND WOULD NOT TURN BACK ON. No matter what i tried, the phone would not charge or turn on. Please help!
¡Resuelto! Ir a solución.
If you were to use a flashtool, it might still not work properly unless you flash with data removal.
Try the following: power button and volume up at the same time. After this, connect to wall socket, charge for 2 hours and turn it on.
Thanks for that. But this will require erasing all photos and videos on my phone. Which i do not want. Is there any other way to repair the phone without deleting my photos and videos?
I´m going to try your solution because I have the same problem with my phone, suddenly it turned off and never turn on again!
@Alexdon Your solution "Try the following: power button and volume up at the same time. After this, connect to wall socket, charge for 2 hours and turn it on." work´s perfectly.
Now I can to performe the next step: system repair.
Five stars for you !! thnx
Great news.
hi men should it turn on when i press power bouton and volume up ?? plzz
@abdoukiller04 it should turn off. Then you should be able to turn it back on by pressing longer on power button.
and what is a wall sucket please guys
