Serious issue on my ZL! Phone not starting up after .253 update + LED notification continuously showing Red!!!
SOLVED
Mindfreak_17
Visitor
Tried even SUS & PCC as suggested but nothing works! My beautiful phone is just lying there....
1 ACCEPTED SOLUTION
Accepted Solutions
Uliwooly
have you try the basic
connect the phone to the wall charger > press and hold power & volume up for 10 seconds > let it charger for 1 hour > try to turn it on again
22 REPLIES 22
Uliwooly
try this
connect your phone to a wall charger > press and hold power & volume up at the same time for 10 seconds > let it charge for 1hour > try to turn it back on
Mindfreak_17
Visitor
Trying this... hope it works!! 😕
duggu
Visitor
I faced exactly the same problem around 1 week back. It happens when your phone completely runs out of battery.
What i did was continuosly pressing the volume up and power key while charging it. When this thing also failed i connected it to pc and then it suddenly started. :smileylaugh::smileysilly:
The permanent solution to this is to charge often...and never let your battery drain completely.(Neways draining your battery frequently will shorten its life)
Mindfreak_17
Visitor
Didn't work... :'(
Mindfreak_17
Visitor
i had actually let it drain completely on the first day so that i could leav it for charging from 0 - 100... will try connecting to my pc again now...
Teng
Visitor
http://talk.sonymobile.com/message/466566#466566
2weeks ago.. Vinay click the link. thats how i solved my ZL
Mindfreak_17
Visitor
I will try this today & confirm Teng! tks!
Mindfreak_17
Visitor
No luck... it managed to recognise the card but still did not turn on the fone.... :'(
Mindfreak_17
Visitor
It allowed me to run the full update on the fone via pc (778 mb) but still doesnt turn it on Slightly_frowning_Face helpppppppppppppp
