That is interesting, I will see if I can replicate that here and I would be very interested to see if anyone else can confirm this.
Don't forget to mark posts that answers the topic as Accepted Solution.
If you find any post helpful, press Kudos.
What are your thoughts about this forum? Let us know by doing this short survey.
Yes, this problem came up some time ago, I personally spent a lot of time to help someone because we thought it is something about the SD card. One of the crew just head-shoot me with this idea and it actually was it - the paypass/paywave card in the same cover and close onught to trigger the NFC.
It's very easy to replicate, just close your credit card to the phone and it start yalling "read error" because it doesn't recognize the chip there
I am sure you helped a lot of people dude
@Foxxi - Hi and welcome to the community! Since you're new please be sure that you have checked out our Discussion guidelines.
You can still use the case for holding the card if you wish, just turn off NFC when you are not using it:
Main Menu Settings > More > Untick NFC.
