Solved! Go to Solution.
Hi Ashroft98,
Unfortunately, I have not tried any application on my own that can control the LED-light. But if they interfere with STAMINA-mode, have you checked if it's possible to add the app as active in standby via Settings > Power management > STAMINA Mode > Apps active in standby?
Hi Ashroft98,
LED works well in STAMINA mode, notifications, walkman, battery charge or discharge, work fine.
