That is certainly not normal, about 2.5 hours would be ok unless you have a lot of data/process heavy applications installed that run in the background. The next time you need to charge it, reboot it then put in on charge and let us know if there is a difference in charging speed.
What are your thoughts about this forum? Let us know by doing this short survey.
Remove the charger when your phone shows 100% battery, it's common sense
too long for me. from 0 to 100 % i believe not less than 4h
if you charge your phone through a computer or car charger it will take longer than a wall charger.
yes endeed ! through usb it's more than 5h
are you saying that if you charge your phone through the Sony wall charger it takes 5hours?
something around 4h through a wall charger, yes.
More than 5h through usb connected to the computer.
Ce message a été modifié par: ryuhadoken
that doesn't seem right, unless you are using the phone while charging and/or if you are downloading or if you leave the wifi on then it will make sense it take that long.
Since the begining it's like that but the battery seems to be ok and the % charge decrease normally
perhaps there is an issue with your wall charger or cable.
