Solved! Go to Solution.
about 500 full charge cycles, after that the battery won't hold as much charge as it does right now, eventually you will have to replace it.
Not sure I understand your issue - Is that that you charge your device every day? or twice in three days?
So can the battery be replaced or will i have to replace the phone? my battery currently cannot hod charge for more than 5 hours at the maximum.
You can replace the battery at your local Xperia Care or you can DIY
