battery life
SOLVED
NirmalSitaldin9
Visitor
battery life
Guys, how long should the average Z2 battery last? In hours pls
36 REPLIES 36
Uliwooly
post a similar screenshot once the battery drain down to 10% or so
NirmalSitaldin9
Visitor
Uliwooly
I can't see the picture until it's approved by a moderator
mushtaq544
Visitor
Hi,
Does stamina modes effect battery health?
Is it okay to keep my stamina mode on all the time or it will have negative impact on battery??
Please let me know..!!
NirmalSitaldin9
Visitor
@mushtaq544 Hi! You can keep Stamina Mode on for it will only increase your battery time and it won't have any negative effects on the battery.
z2user87
Visitor
Im using sony z2 . Same problem here ....i felt like when i was in kitkat i had more battery backup...after each update the  battery backup came down ....5.1.1 is the worst update- too much battery drain.
NirmalSitaldin9
Visitor
Hi @z2user87 If you've updated not too long ago, it might be so that the phone needs to regulate with the changes from the update. Wait 2-3 weeks, restart your device frequently (2-3 times a week) and the battery drainage might become normal again. If you experience severe battery drainage even after a few weeks, factory reset your phone and use Helium to back your apps up.
