Solved! Go to Solution.
Mobile data speed and strength is related to the signal itself. So you might see a drop in battery life.
No,it is not normal. Could you post a screenshot of the battery graph under power management?
Understood. Don't forget to restart the device from time to time.
No one can give you an exact answer to that question, as it depends on how many apps, which services/apps you are syncing, how often you sync them, how often you use your phone, phonecalls, videos, videogames, music, also a HUGE issue could be the network coverage
That's normal
