Smartwatch and car bluetooth
Jtalty
Visitor
Has any one connected a smart watch and car blutooth at the same time using the xz premium? Every time i do this i cant make calls from the car unless i disconnect the watch from Bluetooth
6 REPLIES 6
CameronT
Champion
Hi @Jtalty, welcome to the community.
While you can have multiple bluetooth profiles on your phone, you can only actually have one bluetooth device connected at a time.
You will not be able to have both the watch and the car bluetooth connected at the same time.
I am wrong. You can have multiple devices connected under different profiles as others have said. Because your Smartwatch uses a voice profile, this is likely why you cannot connect it to your car audio at the same time.
Jtalty
Visitor
Ah ok thats disapointing as i used to have a s7 edge and i would connect both. Is this a limitation on the phone ?
Wakin2000
Visitor
Noop, connect differ bt profile on two bt device is always possiable on my xperia.
Tags (1)
Jtalty
Visitor
Yes but if im connected to my watch then get in my car it wont connect unless i disconnect the watch
profile.country.US.title
Qatrium
@jtalty23
@Jtalty
You can connect multiple Bluetooth devices to your phone at the same time, but on different profiles. That means you can't have 2 devices that handle phone calls active at the same time.
I also have the car kit plus my smartwatch connected at the same time to my XZ. Only the watch is on call management profile, while the car kit is on audio only. So I have my smartwatch handling calls while I use my car kit to handle other audios (like music, navigation, etc.).
Jtalty
Visitor
So basically when i wont to use my car to handle calls i have to manually disable the watch for calls so the car can connect to the Bluetooth for calls
