Hello, I use on my last htc 10 here drive as basic navigation.
On my XZ premium this app do not work. After installation the app stops.
I reinstalled several times, made hard reset, after several updates including last 45.0.А.7.120 the situation is the same.
Please, help me.
have you tried contacting the app's developer? it's them who will probably release a fix in an update once they learn about the bug.
I wrote some letter to developers.
Thank you.
Are there other users with the same problem?
I bought sygic navigation and everything is fine.
Yes, I#m not the only one with HERE problems. I try out some older versions and with version 2.0.11260 HERE is working. All other newer versions are force closing.
I've contact the HERE support and they told me, that this is a known issue and they are working on it. This was in june. So.........
If you want use HERE, then search for version 2.0.11260 APK and try it and don't update it
