Hi, my charger port on my Sony XZ is a bit rubbish, every cable I use seems to pop back out after I plug it in. This is making it difficult to charge at night and subsequently unreliable. Is there some kind of fix for this or a new cable I can get, I have the same problem on all 3 cables,
thanks,
Séamus
Hi @seamagu1
Sorry to hear about this
If you have tried different cables and they all seem to pop out and not fit correctly, I would advise contacting your Local support for further help.
It sounds like you will need to have the phone assessed and repaired by a service centre and they will be able to help you organize this.
Good luck
