Hello
I have a problem on my XSP. The power on/off/lock/unlock doen`t work. I can lock/unlock the phone but I can`t shut down/power up the pgone from there. is this a software problem or a hardware problem? Anyone else encountered this?
Hi,
That sounds very strange. Did you do anything special with the phone when this behaviour appeared? Installed a specific app for example? If not, I suggest that you make a factory reset via Settings > Backup & reset > Factory data reset. Otherwise, you should visit nearest service center to have your phone examined by a technician. You can contact your local support team for further information about how to proceed with this in the best possible way:
http://www.sonymobile.com/global-en/support/contact-us/contact-info/
