A question from a friend: "Can I pick your brain about the Sony tablet? If I were to get the 3g version can I use a standard sim card from my phone in it to use the data I already pay for on my phone? Also can you use flash player with it? I used an ipad and was amazed at the amount of stuff I couldn't access with it!"
Cheers
Faith x
Solved! Go to Solution.
I believe it takes a 'standard' sim not the smaller 'iphone 4' type - I'm sure I read that but have been unable to find where I read it and the manual doesn't really tell you!
That said I have to wonder about the 3G option - personally I decided against it as I spend 90% of the time in wi-fi range of some description. For the other 10% I have a 3 MyFi access point that can be used with any the many family data devices.
With regards to Flash works perfectly and if you so chose auto updates - never had any issue with flash although have seen it on my iphone4 and think it's a pain a definite plus for the Sony Tablet S.
Hope this helps
Padster
Message was edited by: mpattenden
Message was edited by: mpattenden - typo - doh!
Flash player is available.
I don't know the sim card's dimensions, sorry...
Hope this helps
Padster
Padster is correct the Sim card used in the 3G Tablet is a standard Mini Sim
As to wether the sim from your friends phone will connect is a different matter..
Depending on the Phone your friend has they could try tethering - What is Tethering but check there are not additional network costs first..:smileywink:
cheers guys, as usual, you come up trumps
I'll pass this info on to my friend
Faith x
You're welcome Faith, will your friend be joining the forum.?
haha, could you imagine more midwives on here lol, it could get messy
Well if she does decide to get the tablet I will defo suggest it
