Hi. I have a problem to running openvpn on my z3 tablet. On my z1 compact its running without any issues. I use only original firmware. No jailbreaks or custom roms.
working device z1 compact
android 5.1.1 build 14.6.A.1.236
openvpn client 1.1.17 (build 76)
not working device z3 tablet compact
android 6.0.1 build 23.5.A.1.291
Connection will be established successfully. But if load any network traffic i get
UDP send error: send: Operation not permitted
UDP send error: send: Connection refused
Any ideas? I would be thankful if you can help me.
Greetings
knollo
¡Resuelto! Ir a solución.
oh my god. i found this post
https://forums.openvpn.net/viewtopic.php?t=21178
stamina mode is to aggresiv. with stamina off it works fine. so problem is solved.
greetings
knollo
greetings
knollo
