Camera Problem
pylyp
Visitante
Camera Problem
Camera was working and stop.I don't do anything. It's just stop work. When I try to start camera it's write "unhappily the camera stop working". That's it. Camera as device is working. Thru Instagram I can make pictures. That's the problem?
13 RESPUESTAS 13
Uliwooly
try this
Settings > apps > all > camera > clear everything > restart your tablet > try again
pylyp
Visitante
I was trying and it's still not work
Johan
Máster
In that case you might want to try reinstalling the tablet software. Use Update Service to reinstall it and check if you can get the camera application working again.
http://www.sonymobile.com/gb/tools/update-service/
pylyp
Visitante
Sorry but this software is for Windows.I have Android in Ukraine
pylyp
Visitante
Try to update my Android from Settings/install new version, but it still not working
Sam
Leyenda
Leyenda
Please try following Johan’s advice. We are aware your phone is running Android however the software in question needs to be installed on your PC which will then connect to your phone to repair the software.
Don't forget to mark posts that answers the topic as Accepted Solution.
If you find any post helpful, press Kudos.
What are your thoughts about this forum? Let us know by doing this short survey.
pylyp
Visitante
OK, I reboot my system. And it's dosen't working at all.
Do you have some another ideas?
Thank you.
Sam
Leyenda
Leyenda
When you say "reboot system" do you mean that you have run the software repair as above?
pylyp
Visitante
Yes, I instal program, which you sugest. After I connect my computer to tablet and reinstal the Operational system.
