Xdr-s1 dab radio
Ladybird
New
Xdr-s1 dab radio
My xdr-s1 dab radio has stopped working. When I turn it on there is a very faint flashing AM 12:00. None of the buttons change this display. Is this a fixable problem or do I need to discard my radio and get another? Thank you for your help
2 REPLIES 2
TheGOAT
@Ladybird Try resetting it manually, there is a button on the back as the manual says, you need to press it with a pointed object to revert it to the factory preset, check this in section (A): https://www.sony.com/electronics/support/res/manuals/3265/32657231M.pdf
Ladybird
New
Thank you for your help. I didn’t do the factory reset as when I tried the radio the next day it worked. I think I may have splashed it when I cleaned the sink and it needed to dry out.
