Sony ULT TOWER 5 – Software and Firmware Improvement Suggestions
Dear Sony Product Development Team,
I recently purchased the Sony ULT TOWER 5 and, after spending time using it, I would like to share some suggestions that could improve the overall user experience. I believe most of these improvements could be implemented through future firmware or software updates.
1. Lighting Customization
I would like to see more flexibility in the lighting settings:
- Adjustable brightness: Currently, the lighting can only be turned on at maximum brightness or completely off. It would be useful to have adjustable brightness levels.
- Independent ULT button illumination: The ULT button should remain illuminated even when the main lighting effects are disabled, with independent control.
- Automatic lighting cycle: Add a mode that automatically cycles through all available lighting effects.
2. System Sounds and Bluetooth Notifications
The system sounds are excessively loud, especially the startup and Bluetooth connection/disconnection sounds. This makes the speaker difficult to use at home, particularly at night when other family members are sleeping.
Although the Sony application provides an option to disable sound effects, Bluetooth connection and disconnection sounds remain active and extremely loud.
I would suggest:
- Allowing independent volume adjustment for system sounds.
- Ensuring that disabling sound effects turns off ALL system sounds, including Bluetooth notifications.
- Introducing a Quiet Mode or significantly reducing the default notification volume.
If users choose to keep these sounds enabled, they should play at a much lower volume.
3. Bass Performance in ULT 2 and LIVE Modes
ULT 1 sounds excellent and delivers powerful, deep low-frequency bass. However, ULT 2 and LIVE modes seem to significantly reduce or almost completely remove the low bass frequencies.
I would like Sony to improve these modes:
- ULT 2: Preserve the low bass frequencies at the same level as FLAT mode while adding more emphasis to the upper bass.
- LIVE: Retain the low bass frequencies instead of cutting them.
The different sound modes should have their own characteristics without unnecessarily sacrificing deep bass. ULT 2 and LIVE should maintain a solid low-frequency foundation while enhancing their respective sound profiles.
4. Battery Monitoring
Currently, the speaker announces the battery level only when it is powered on. During playback, users must open the Sony application to check the remaining battery.
I would suggest:
- Allowing users to check the battery level directly from the speaker, even while music is playing.
- Adding a long-press function on the STAMINA button to announce the current battery percentage.
- Improving battery percentage accuracy. Instead of displaying the level in 20% increments, show the actual percentage in 1% increments.
For a premium speaker released in 2026, more precise and accessible battery information would be a welcome improvement.
Final Remarks
I really enjoy the Sony ULT TOWER 5 and believe it has great potential. These suggestions are intended to improve its functionality, flexibility and everyday usability.
I hope Sony will consider these requests for future firmware and application updates. I would also appreciate it if this feedback could be forwarded to the Product Development and Firmware Engineering teams.
Thank you for your time and consideration.
Best regards,
A Sony ULT TOWER 5 owner
