Sony Linkbuds wf-l900 problem!!!
RESUELTAS
profile.country.GR.title
Stelios13ser
after the last update I have a problem with the adaptive volume control .. you ??
1 SOLUCIÓN ACEPTADA
Soluciones aceptadas
Anonymous
No aplicable
Hey,
Can you try to uninstall the app and reinstall it once more?
Also, you can reset and initialize the earphone, then test it once more: https://bit.ly/3y32Ony & https://bit.ly/3y4fWJg.
Hope it helps.
5 RESPUESTAS 5
Anonymous
No aplicable
Hey there,
What's the issue exactly? You can provide us with more information about the issue itself, maybe we can assist further.
Cheers.
Stelios13ser
my problem is.. i have the adaptive volume control turned on but it does not work. does not fluctuate in any environment, is stable.
Anonymous
No aplicable
Hey,
Hope it helps.
Stelios13ser
thanks for the help..but the problem is not solved. I have tried both but no luck and tried the same result on another phone.
Stelios13ser
good morning. after a second attempt from the instructions you gave me everything seems to work again..thank you !!!
