Aiwa AM-F70 Mini disk Recorder
holddy982
Hello.
          Can any one please help me with a problem I have with an Aiwa AM-F70
mini disc player,, The instructions tells me to connect to another unit unit like a
home stereo via a optical cable or a 3.5 jack to phono,,  but there is nothing to say
how to connect to my computer,,I have tried to connect via a 3.5 jack from the
AM-F70 to a USB but the computer does not see it, Plus I can't find a driver for it.
can anyone tell me how to connect to the computer.
        Now here's a good on for you, can anyone tell me where to get a battery for it,
the one in it is a genuine Aiwa li-ion,  lib-902 Lithium battery, I can't find one
anywhere, maybe i am looking in the wrong place, can some one please point me
in the right direction.
If anyone replies to this request Thanks for your help and thanks also to them
that reads this.
                                       Cheers Tony
1 RESPUESTA 1
Anonymous
No aplicable
Hi there
I have had a look at this, and you should have a 3.5mm connection (see pic below):
Therefore, you would probably need a 3.5mm to 3.5mm cable.
http://www.amazon.co.uk/3-5mm-Stereo-Jack-Plug-1-2M-Black/dp/B00077DC3S/
In regards to the battery, unfortunately it is no longer available.  Ebay might be your best bet.  I did find out that the part number = U-0130-979-U
Cheers
