Hi
I don't know if this is a problem with the actual laptop or not. When I turn down the brightness of the screen either by using the power save option or by using the Vaio control centre, I get a buzzing noise after a while, which just gets louder and louder. It stops when you put the brightness back to full.
Any thoughts? Is there an easy fix or will I need a repair/replacement?
Laptop is a month old.
Thanks
I couldn't tell you why it happens, but it's normal. My FS series does it too.
I get this too. I'd kept it on 'maximum' brightness, so the buzz on any other brightness level was quite a surprise... it happened about a week after machine purchase, so I was a bit concerned I had a defective one. The machine is an AR31s, but I never had this issue with my old A417m.
Hi all,
I remember reading something like this with another Vaio series, I think it may be worth contacting Vaio-Link for clarifiaction..
Thanks for that advice. Have registered and opened a case. Will let you know if I get a resolution.
Jude
You're welcome Jude, I would be interested to know the out come, could you let me know please..
Hello, i got the same problem with my C1Z/B! Its very annoying when theres total silence arround!
