Vaio external monitor
petestenny
Visitor
I have a Vaio PCG-K315Z and originally had 2nd monitor option to allow me to use the 3.5mm jack output to 3 phonos for TV input. I also used to be able to switch between laptop screen, laptop screen and TV or just TV. This option no longer appears. Via control panel and display I now only have radeon as options for both monitor 1 and 2. How can I get the external monitor and switchabilty back?
Also I have a DTV USB stick to allow me to get freeview channels. I'm travelling to France will I be able to view their free to air channels in colour as they broadcast in Secam not PAL or will I only be able to view in black and white?
5 REPLIES 5
profile.country.de_DE.title
seb21__
Visitor
I know from Pal TVs which doesn't support secam, the picture is in black/white.
so, the fault could be your USB TV card.
rich912
Contributor
From this I take it that you have no Displays tab in the Advanced options of Display Settings > Settings tab. If this is the case you will probably need to re-install the Video driver - you will find this in the pre-installed driver download, for your model, at Vaio-Link.
If, however, it is the Fn+F8 utility that is the problem then re-installing the utilities should solve this.
Go n-éirí an bóthar leat
profile.country.en_GB.title
kee-lo_
Member
When I brought my Intelevision games console to England in 1985 I couldn't get a picture from it, as it's SECAM, so it won't work the other way round
Thalamus.
Champion
In Start > Vaio control centre > List > Plug and display, there is an option to enable 'Show display switching window when external display is connected' not sure if it's as simple as that though?
tonybeard
Explorer
System restore to a time when you had both options
