39 day ago we buy a PCV-W2 and now I stop to use PCV-W2 for problem with giga-poket software / card.
Like AF we see the error of loosed ID.
We try to reinstall a giga-poket software but we see also to loose all parameter setting card like " trasmision area"
Than we try to fix it but several time W-XP crash with BEEP
mouse - task manager -explorer bar block any activity.
We watch a particular sistuation , all video streming block the system (mouse keyboard and than BEEP) same explorer block the system , same time with menu vaio when we use a remote control to start a video software; is impossible to connect the pc to the net for most then 3 minut, after BEEP.
I see this problem after 20 hours of Stand-By with TV tuner ON
We check the high temperature on the bios setting and i think is good arround 40 °C, all fan working.
After check all possible cause and read all document in the net about this tipe of problem in PCV W2 and other PC I decide to replace the Operative System to the DRIVE C:
We watch the manual at the section replace Operative System with the original CD rescue of SONY. ( before we check the section for W-XP SP2 and check my system, we alredy has new SP2 installed on my PC from the electronic-shop)
We start a new installation , all OK, restart the PC for reboot and setting start
and he crash on the page of Computer Name and continuos and continuos block the system on this page.
Now we don't use my PCV-W2 because it doesn't start for reinstall the Operative System.
Please wath can we do ?
Many Tanks for any solution.
ciliegina
Arrange with VAIO-Link for a pickup
