So many questions recently, I wondered if you could help with one more...
When running the vaio from battery power there is a lot of interference (noise?) through the speakers. However this disapears when connected to the power supply. Can this be cured? I tried the advice in another thread about making the vaio run silent and installed the suggested program but it had no effect.
Thanks in advance...
Hi pringe83,
Is the screen brightness set to full when running on batteries?
If not does the interference (noise?) through the speakers disappear if you increase (FN+ F6) the brightness level to full..
Hi Thalamus, thanks for the reply. I've done a bit more experimenting and have a revised set of symptoms:
bump...any ideas?
When running on batteries the noise doesn't come through the speakers; instead it comes from the screwed down panel directly underneath the trackpad. What is this?! (EDIT: This is apparently the memory compartment cover. How can noise be coming from this area?! I can assure you it is from here!)
Is it just a buzzing or like a screw loose?
!confused.gif|___jive_emoticon_name=confused|jivemacro=emoticon|class=jive_macro jive_emote|src=confused.gif!
Hi Matt - it is most definitely some kind of electrical noise. Very high pitched. I'll try to get a recording of it posted up here. It seems that the noise is consistent with the hard drive activity (ie seems to get louder when drive is being written to or reading), yet also present when hard drive is inactive. Very strange.
