MemoryStick Duo not recognised
chrismm
Visitor
My PCV-RX201 recognises a 64Mbyte memory stick but not a 256 Mbyte memorystick duo in adapter.
Does anyone know why/
5 REPLIES 5
rich912
Contributor
Hi Chrismm and welcome to the forum.
Not sure about this but the problem may be that the 256 Mbyte memory stick is ‘Dou Pro’, not all Sony devices will recognise this.
Go n-éirí an bóthar leat
William
Visitor
If it is a "Pro" issue, have you tried VAIO LINK . I only looked under XP but there are two Memory Stick updates for your model which together may reolve the problem.
profile.country.en_GB.title
kee-lo_
Member
God I hope RA104 can see Duo Pros..........
William
Visitor
If it helps Kee-Lo my RZ did (in its adapter) and it is a LEXON not Sony :smileygrin: .
But if you are talking PSP you won't really need to remove it from the PSP, instead just connect the PSP with a USB cable.
kee-lo_
Member
Nah, talking 'bout my baby off Sony :slight_smile:
