Sony Kdl32u3000 no hdmi input
Maha24
New
Hi guys Im having trouble with my Sony kdl32u3000. I have connected my laptop via hdmi cable to the tv, and my laptop shows I have succesfully connected it to a Sony TV. The problem is there is no hdmi input for me to select, the options I have are TV, AV1 AV2, AV3, AV4, AV5, AV6, PC. I have tried all of these with no succes. I have done a reset of the tv as well. I have tried going to settings-hdmi set up, but when I connect my laptop it just says no device detected despite "seeing" Im connected on the laptop. Any help is appreciated, thanks in advance.
1 REPLY 1
Anonymous
Not applicable
Hi there
HDMI Ports:
Top HDMI (4) = AV4
Bottom HDMI (5) = AV5
If your having problems receiving a signal from your PC, you need to change the display (resolution) settings on the PC, to one that is compatible with your TV.  See table below:
undefined
Cheers
