My sony xperia t2 ultra is in a bootloop, what can i do?
Remove both SIM and SD cards, if you experience the same issue then it might be a hardware issue.
Hi @JO6EX21,
Welcome to the community.
I'm sorry to hear this. As @uliwooly suggested you can try to temporarily remove your SIM and SD card from your device to see if they are causing this behavior.
You can also force shutdown your device by holding down the volume up and on/off key for at least 10 seconds.
If you are still experiencing the same behavior with your device, I recommend that you perform a software repair using Xperia Companion to see if anything software related is causing this behavior.
Let me know how it goes.
