Solved! Go to Solution.
Hi @Wasukhan, I'm very sorry to hear about your phone.
Could you try removing SIM- and SD cards if you have them mounted, and then force a shutdown of the device? To force a shutdown, press and old the OFF button located at the back of the device (dismount the back cover first) with the help of a pen or a similar object. Once you've done that, try starting the device again to see if it boots correctly.
If it persists, then I recommend that you perform a software repair using Xperia Companion, but please note that all data stored on your device will be lost as the software repair replaces the system with a fresh one.
Let me know how it went!
That sounds like a good idea, keep me updated!
